How can send triggers by SMS in zabbix
  • bab
    • Aug 2020
    • 197
    I want to send SMS for triggers with via api . as you can see I am using follow script but it cannot send sms when there is Space in trigger alarm (All times we have space in trigger alarm) for example when trigger alarm is : /usr space is more than 90% it cannot send it . I think had to change in curl command or script to solve the issue would you please help me about it? Also I did all configure in media type and ... just the problem is with SPACE character .
    msg="$1"
    numbers=('123456789')
    for sms in "${numbers[@]}"; do
    curl -i "http://SMS-SERVER-IP-ADDRESS:PORT-Number/sms?src=Source-Number&dest=$sms&msg=$msg&apikey=MY-API-KEY"
    done
  • Answer selected by bab at 18-06-2022, 07:52.
    Markku
    • Sep 2018
    • 1784
    This might help you: https://stackoverflow.com/questions/...r-curl-command
    You can as well encode the query string:
    curl --get \
    --data-urlencode "p1=value 1" \
    --data-urlencode "p2=value 2" \
    # http://example.com?p1=value%201&p2=value%202
    Markku
    • Markku
      • Sep 2018
      • 1784
      curl --get \
      Markku
