Zabbix Agent 2 SMART Plugin smart.disk.discovery issues on Windows
  • mfitzy
    • Jun 2016
    Good morning,
    I've recently upgraded our Zabbix installation to 6.0 LTS.
    I wanted to take advantage of the official zabbix smart monitoring plugin on some Windows 10 Hosts.
    On them I've got:
    • Zabbix Agent 2 v6.0.5
    • smartmontools 7.3
    • smartctl in the PATH environment variable
    On systems with just nvme disks, everything works fantastically.
    On systems with SATA drives, I noticed that discovery times out, and system CPU usage spiking heavily.
    On further inspection, it looks like the Zabbix agent was opening a bunch of instances of smartctl.exe and rapidly closing, with increasing numbers of this making the system sluggish.
    I increased DebugLevel to 5 to see what was happening and it looks like zabbix is looping through device types that seem to not be supported by smartmontools on windows:
    2022/06/17 10:05:41.280692 [Smart] command smartctl -a /dev/sda -d 3ware,1 -j smartctl raw response: {
    "json_format_version": [
    1,
    0
    "smartctl": {
    "version": [
    7,
    3
    "svn_revision": "5338",
    "platform_info": "x86_64-w64-mingw32-w10-21H2",
    "build_info": "(sf-7.3-1)",
    "argv": [
    "smartctl",
    "-a",
    "/dev/sda",
    "-d",
    "3ware,1",
    "-j"
    "messages": [
    "string": "/dev/sda: Unknown device type '3ware,1'",
    "severity": "error"
    "string": "=======> VALID ARGUMENTS ARE: ata, scsi[+TYPE], nvme[,NSID], sat[,auto][,N][+TYPE], usbcypress[,X], usbjmicron[,p][,x][,N], usbprolific, usbsunplus, sntasmedia, sntjmicron[,NSID], sntrealtek, intelliprop,N[+TYPE], jmb39x[-q],N[,sLBA][,force][+TYPE], jms56x,N[,sLBA][,force][+TYPE], aacraid,H,L,ID, areca,N[/E], auto, test <=======",
    "severity": "error"
    "exit_status": 1
    "local_time": {
    "time_t": 1655417141,
    "asctime": "Fri Jun 17 10:05:41 2022 NZST"
    It does this for 3ware, areca and cciss types, looping forever until I stop the agent.
    I can't seem to find a way to disable checking for these device types, or anything I can configure to get around this. Does anyone have any insight?
    I did find a forum post in the Russian forums that could be the same issue, but not 100% sure: https://www.zabbix.com/forum/in-russ...plugin-windows
  • mfitzy
    • Jun 2016
    Tried different versions of Smartmontools, but looks like none of them have the called options.
