net.tcp.service not working with ports different than 80,443
  • darkrigel
    • Jun 2022
    Hi
    Zabbix 6
    Red Hat. Firewall off for testing
    This simple check is not working, it always return 0.
    net.tcp.service[https,x.x.x.x,10443] or net.tcp.service[tcp,x.x.x.x,10443]
    There is a web in that port that is up and working. I have try other ports (6443, 5443...) with same result.
    This configuration is working, it's returning 1.
    net.tcp.service[https,x.x.x.x,443] or net.tcp.service[tcp,x.x.x.x,443]
    From the host I can ping the ip, telnet ports, and curl both webs.
    There is nothing on zabbix logs related to port 10443, it's like zabbix is not doing anything.
    Do I need to make an special configuration on zabbix6 to monitor "non-standard" ports?
    Thanks!
  • Answer selected by darkrigel at 22-06-2022, 10:45.
    cyber
    • 4996
    If you want to determine whether zabbix can connect to all TCP ports, you must turn on the zabbix_can_network boolean. Disabled by default.
    setsebool -P zabbix_can_network 1
      • 4996
      • darkrigel
        • Jun 2022
        Resolved, thank you so much!!
