Trigger based on latest data output
  • lovezabbixaj
    • Jan 2016
    • 9
    I am using item key "eventlog[Application,,,Winlogon,4005,,]" and I am getting correct output in the latest data section.
    Output: The Windows logon process has unexpectedly terminated.
    Can I have a trigger based on this data. Something like a trigger which gets generated if the output has string "terminated" in it ?
    Please help.
  • Firm
    • Dec 2009
    • 342
    {<host>:eventlog[Application,,,Winlogon,4005,,].str(terminated)}=1
    • lovezabbixaj
      • Jan 2016
      • 9
      Thanks a lot! This worked .
      But this will send a trigger if the string is found anywhere in the output. Is there a way to get a trigger if the output matches the exact string.
      For eg: if output is only "terminated." I want a trigger to happen if the output is only "terminated".
      It should not trigger if output is "The Windows logon process has terminated." where there is a string "terminated" somewhere in the output.
      • Firm
        • Dec 2009
        • 342
        {<host>:eventlog[Application,,,Winlogon,4005,,].regexp("^terminated$")}=1
        P.S. Zabbix suggests to create trigger for character/text items.
