Installation of ZAbbix on Ubuntu 22.04
  • MightyP1
    • Jun 2022
    Getting the errors below... Can anyone help?
    111admin@P1Ubuntu1:~$ apt update
    Reading package lists... Done
    E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
    E: Unable to lock directory /var/lib/apt/lists/
    W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
    W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
    Trying to install a fresh copy but.... Is ubuntu 22.04 not supported?
  • Markku
    • Sep 2018
    • 1784
    You need to be root (or use "sudo") when running "apt update".
    However, according to Zabbix download page (https://www.zabbix.com/download?zabb..._jammy&db=&ws=) there are no packages yet for Ubuntu 22.04 (except for Zabbix Agent).
    Markku
    • derli1988
      • Apr 2021
      • 60
      It's not supported, not even when running 20.04 and trying to upgrade the OS after
