Query and combine multiple SNMP OID values in one item?
  • jjeff123
    • May 2022
    • 35
    Trying to update the HP Enterprise SNMP to gather data for the Aruba CX. The CX switches have multiple CPU cores and % utilization can be gathered for core 1 via OID 1.3.6.1.2.1.25.3.3.1.2.196608, core 2 1.3.6.1.2.1.25.3.3.1.2.196609....
    So what I want, is to basically do an SNMP walk of all the values returned by 1.3.6.1.2.1.25.3.3.1.2 and average them together.
    I am far from an SNMP expert, I can have the switch query itself, on an Aruba 6100 (basic layer 2 CX series), I get this:
    Switchname# diag utilities snmpwalk oid .1.3.6.1.2.1.25.3.3.1.2 community public
    HOST-RESOURCES-MIB::hrProcessorLoad.196608 = INTEGER: 21
    HOST-RESOURCES-MIB::hrProcessorLoad.196609 = INTEGER: 22
    The larger boxes have more cores.
    So no problems getting one OID into Zabbix, it happily tells me the value for core 1, but I don't want to make a separate template for each model based on the number of CPU cores.
  • rogzon
    • Oct 2023
    Hi! I know this is a rather old post but...
    Did you ever figure this out?
    • Hamardaban
      • May 2019
      • 2714
      walk[]​
      • rogzon
        • Oct 2023
        Great, that would do it but.... I am having a hard time to understand how to combine the OID results i.e (OID #1 + OID #2)/OID #3 to get one single result. OID #1 and OID #2 would be counters and OID #3 is Gauge.
        As it seems the preprocessing could only handle one change per second preprocess?
        I am trying to get rid of "Bits received", "Bits sent" and "Speed" in favour of a proper Throughput number with attached trigger in a discovered item from a network switch.
        I am also trying to keep the "Latest data" monitoring screen from getting cluttered with items I don't really need (right now I am calculating throughput but that means that Bits sent/received and speed needs to be discovered for use in calculation).
