How can create a trigger with specific parameters
  • bab
    • Aug 2020
    • 197
    I have wrote a script that returns a string such as the table space usage is more than 90% (warning) and table space usage is more than 95% (disaster)
    but when I want create a trigger how can define when it meet 90% in this string "the table space usage is more than 90%" show warning and when meet 95% in this string "table space usage is more than 95% " show disaster ?
  • vladimir_lv
    • May 2022
    • 240
    Can trigger dependencies help you?
    Just create 2 triggers. The first one, "90%" depends on the second trigger "95%".
    • bab
      • Aug 2020
      • 197
      https://www.zabbix.com/documentation...s/dependencies
      As I said in the previous post the output message is "table space usage is more than 95%" this is more than one character . How can define warning trigger while it shows "table space usage is more than 90%" and define critical trigger while it shows "table space usage is more than 95%" ?
