Enable trigger between specific time
  • bab
    • Aug 2020
    • 197
    This is my trigger :
    min(/Linux by Zabbix agent - DBA/vfs.dev.read.await[{#DEVNAME}],15m) > {$VFS.DEV.READ.AWAIT.WARN:"{#DEVNAME}"} or min(/Linux by Zabbix agent - DBA/vfs.dev.write.await[{#DEVNAME}],15m) > {$VFS.DEV.WRITE.AWAIT.WARN:"{#DEVNAME}"}
    Now I want this trigger just enable between 13:00 - 17:00 everyday . How can do it ?
  • Answer selected by bab at 26-06-2022, 05:17.
    Markku
    • Sep 2018
    • 1784
    You are missing a closing )
    Markku
    • Hamardaban
      • May 2019
      • 2714
      add to the trigger expr “and time()>130000 and time()<170000”
      • bab
        • Aug 2020
        • 197
        Thanks. I changed my trigger such as below :
        min(/Rac1/vfs.dev.read.await[{#DEVNAME}],15m) > {$VFS.DEV.READ.AWAIT.WARN:"{#DEVNAME}"} or min(/Rac1/vfs.dev.write.await[{#DEVNAME}],15m) > {$VFS.DEV.WRITE.AWAIT.WARN:"{#DEVNAME}"} and time()>130000 and time()<170000
        But another it shows trigger in the problem :
        sddj: Disk read/write request responses are too high (read > 20 ms for 15m or write > 20 ms for 15m) at 04:20AM
        • Markku
          • Sep 2018
          • 1784
          See https://www.zabbix.com/documentation...sion#operators("and" is evaluated before "or").
          You need to use parenthesis around your original "X or Y" statement when you combine it with something with "and" operator.
          Markku
          • bab
            • Aug 2020
            • 197
            Markku
            Changed it to :
            min((/Linux by Zabbix agent - DBA/vfs.dev.read.await[{#DEVNAME}],15m) > {$VFS.DEV.READ.AWAIT.WARN:"{#DEVNAME}"}) or min((/Linux by Zabbix agent - DBA/vfs.dev.write.await[{#DEVNAME}],15m) > {$VFS.DEV.WRITE.AWAIT.WARN:"{#DEVNAME}"}) and time()>130000 and time()<170000
            but does not work and invalid parameter . Would you please change it or correct ?
            • Markku
              • Sep 2018
              • 1784
              (min() > xxx or min() > yyy)
              Markku
              • bab
                • Aug 2020
                • 197
                Markku
                I changed it such as below (min(/dwrac1/vfs.dev.read.await[{#DEVNAME}],15m) > {$VFS.DEV.READ.AWAIT.WARN:"{#DEVNAME}"} or min(/dwrac1/vfs.dev.write.await[{#DEVNAME}],15m) > {$VFS.DEV.WRITE.AWAIT.WARN:"{#DEVNAME}"} and time()>130000 and time()<170000
                another does not work and show Invalid parameter "/1/expression": incorrect expression starting from "".
                • Markku
                  • Sep 2018
                  • 1784
                  Markku
                  • bab
                    • Aug 2020
                    • 197
                    Markku
                    I changed it as follow . Is that correct ?
                    (min(/Linux by Zabbix agent - DBA/vfs.dev.read.await[{#DEVNAME}],15m) > {$VFS.DEV.READ.AWAIT.WARN:"{#DEVNAME}"} or min(/Linux by Zabbix agent - DBA/vfs.dev.write.await[{#DEVNAME}],15m) > {$VFS.DEV.WRITE.AWAIT.WARN:"{#DEVNAME}"}) and time()>130000 and time()<170000
                    • Markku
                      • Sep 2018
                      • 1784
                      Looks fine, did you try it?
                      Markku
                      • bab
                        • Aug 2020
                        • 197
                        Markku
                        So thanks. It solved.
