Zabbix Server Load
  • rohitkoneru
    • Sep 2021
    Zabbix Server Load
    Hi, Can someone share details on the specs and how much load a Zabbix server can accept with the specs provided (nvps, number of proxies etc..). What default values on Zabbix server need to be modified to accept more messages and connections? can we scale the server up to accept more messages? Looking for a setup that would accept 100+ proxies and each proxy sending 1500 - 2000 nvps.
    Thanks,
    Originally posted by Brucewalker
    Having same Problem. Zabbix server error due to problems with the firewall. As a root user, we check and confirm whether the firewall is allowing connection to Zabbix Server port which is 10051. If not, then we add the following rule in the configuration file /etc./Sysco fig/iptables. Finally, restart the service in order to fix the error.
    How exactly this is relevant to topic starters questions?
