I'm currently testing/learning with Zabbix 2.2 LTS but I'm watching for the final release of the next version of Zabbix 3.0. I'm only starting to use Zabbix so before I add all my hosts and hardware I thought it would be easier to install Zabbix 3.0 and start fresh.
But my questions are regarding the agents I've installed currently for my testing on 2.2:
Thank you in advance for any advice you can give me.
- Are agents for a specific version of Zabbix only or will agents work across versions?
- When I do install a fresh version of Zabbix 3 will I need to upgrade each agent on the hosts I've been testing on for the Agent to work with Zabbix 3?
- Or is it best practice to uninstall the agents I've been using for my Zabbix 2.2 testing when I do install Zabbix 3?
