Actions after Maintenance
  • NeutrALUS
    • Jun 2022
    I have a problem with actions after maintenance mode.
    I would like to create action which can fire send email after maintenance mode if something happend during maintenance mode but not resolved until the end of the maintenance.
    I've create action with two conditions: Problem is not suppressed and Host equals HOSTNAME, operation for Pause operations for suppressed problems is unchecked. But it does not work.
    If i remove condition Problem is not suppressed zabbix will send email during maintenance, but i dont want it.
  • Answer selected by NeutrALUS at 28-06-2022, 10:49.
    cyber
    • 4970
    During a maintenance "with data collection" triggers are processed as usual and events are created when required. However, problem escalations are paused for hosts/triggers in maintenance, if the Pause operations for suppressed problems option is checked in action configuration. In this case, escalation steps that may include sending notifications or remote commands will be ignored for as long as the maintenance period lasts. Note that problem recovery and update operations are not suppressed during maintenance, only escalations.
    So... you you check that "Pause operations for suppressed problems", it should be fine.. You do not need that "Problem is suppressed" condition.
    • NeutrALUS
      NeutrALUS commented
      if i remove condition Problem is suppressed zabbix will send alert during maintenance, but not after.
    • NeutrALUS
      NeutrALUS commented
      ohh, sorry work fine, thank you.
    • 4970
    • NeutrALUS
      NeutrALUS commented
    • NeutrALUS
      NeutrALUS commented
