TCP port monitoring template not working
  • mcflurry
    • Jun 2022
    • 32
    I'm trying to get this template working without success...
    I've followed discovery instructions for agent2:
    Install UserParameter for zabbix-agent2:
    echo 'UserParameter=ss.tcp.listening,netstat --tcp --listening --numeric-ports' | sudo tee /etc/zabbix/zabbix_agent2.d/ss.tcp.listening.conf
    Restart Zabbix agent
    systemctl restart zabbix-agent2
    In this section replace Key:
    system.run["ss --tcp --listening --numeric"]
    with:
    netstat.tcp.listening
    I've imported the template and added it to a Linux host and there's no update about it. Is there anyway to debug this? Am I missing something????
    server:/etc/zabbix/zabbix_agent2.d # ll
    total 8
    drwxr-xr-x 2 root root 4096 Jun 27 12:26 plugins.d
    -rw-r--r-- 1 root root 73 Jun 30 14:43 ss.tcp.listening.conf
    server:/etc/zabbix/zabbix_agent2.d # cat ss.tcp.listening.conf
  • Answer selected by mcflurry at 14-07-2022, 10:55.
    Markku
    • Sep 2018
    • 1784
    Ok, oh well. As you saw from the beginning, the template is not very high quality (the contradicting information about using system.run/ss.tcp.listening/netstat/ss/whatever). So there is a problem in Filter: "Type of calculation" was set to "And/Or" which was in this case evaluated as "Or". Set it to "And", and the filtering starts working properly.
    Markku
    • vladimir_lv
      • May 2022
      • 240
      you have to use the same key in the item (ss.tcp.listening ) as described in UserParameter.
      • mcflurry
        • Jun 2022
        • 32
        Uhm, well, i imported the template and then followed the documentation....
        You mean that this:
        Click image for larger version  Name:	1.png Views:	0 Size:	32.9 KB ID:	447229
        Should be like this:
        Click image for larger version  Name:	2.png Views:	0 Size:	33.0 KB ID:	447230
        And "Key" in "Discovery rule" has to be as it says in the documentation (as it's set in op), Key: netstat.tcp.listening
        • vladimir_lv
          vladimir_lv commented
          Yes, should be like this. Is it working now?
      • mcflurry
        • Jun 2022
        • 32
        I fear not... I've added the template to a linux host and nothings happens... i guess it should discover every open port for that host, or am I wrong?
        I've tested the discovery rule of the template in Configuration -> Hosts and it returns: "Unknown metric netstat.tcp.listening"
        But if i change that to ss.tcp.listening it returns this:
        [{"{#PORT}":"25"},{"{#PORT}":"512"},{"{#PORT}":"513 "},{"{#PORT}":"514"},,{"{#PORT}":"199"},},{"{#PORT }":"21"}
        Does that means that value "Key" in the discovery rule must meet the user parameter and the key in the item???
        • vladimir_lv
          • May 2022
          • 240
          Yes, exactly!
          • mcflurry
            • Jun 2022
            • 32
            Updated everything and it doesn't discovers any port...
            Running "zabbix_agent2 -t ss.tcp.listening" from cli returns all listening ports...
            • vladimir_lv
              • May 2022
              • 240
              [{"{#PORT}":"25"},{"{#PORT}":"512"},{"{#PORT}":" 513 "},{"{#PORT}":"514"},,{"{#PORT}":"199"},},{"{# PORT }":"21"}
              Is this result what you wish to get?
              • mcflurry
                • Jun 2022
                • 32
                Yes, and i guess the javascript will format those ports just to display the port number.
                • vladimir_lv
                  • May 2022
                  • 240
                  Because the result look like:
                  Active Internet connections (only servers)
                  Proto Recv-Q Send-Q Local Address Foreign Address State
                  tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN
                  tcp 0 0 localhost:199 0.0.0.0:* LISTEN
                  you need to use Type of information: Text
                  • mcflurry
                    • Jun 2022
                    • 32
                    If I change that in the item prototype a message shows up: This type of information may not match the key.
                    This is a template, it should be configured almost oob.
                    • Markku
                      • Sep 2018
                      • 1784
                      There is now confusion about the discovery key and the item prototype key.
                      The discovery key seems to be ss.tcp.listening. The item prototype key is something else, whatever was configured in the template, don't edit if you don't know what you are doing.
                      But please clarify this:
                      How long did you wait for the items to be discovered? In the screenshot you showed us the discover interval is one day. Did you wait for one day or less?
                      (I'm currently on iPad so I cannot download the yaml file to see the original setup, sorry.)
                      Markku
                      • mcflurry
                        • Jun 2022
                        • 32
                        Markku
                        You were right, it took hours to update... and i didn't change a thing, just importing the template works.
                        • Zablab
                          • Jan 2022
                          • 28
                          Is there a Windows equivalent version of this? Or, rather, is there a way to monitor multiple ports via single key\template? I want to be able to monitor specific Ports on various Server types, for example:
                          445 on File Server
                          1433 on SQL Server
                          80, 443 on Web Server
                          I know about net.tcp.service[tcp,,{$TCP.PORT}] but that's only a single Port, I'd like to avoid creating a ton of different Marco's or Templates.
                          It doesn't appear I can use Regex for this single Macro, it seems I need to do a discover and filter?
                          From what I gather this version does a full port discovery & then you uses Regex\Java to filter out the ports you want or don't want, this is pretty much what I want to do in Windows, but unsure how to convert this, and I can't find a Windows version.
                          • mcflurry
                            • Jun 2022
                            • 32
                            445 on File Server
                            1433 on SQL Server
                            I haven't found anything for windows like this one.
                            And about this one, I can't get to filter ports. It discover every listening port, so if there are random ports listening it discovers those too... and when the process stop using those ports it complaints about those.
                            I've been playing with the filter and it does nothing.
                            • Markku
                              • Sep 2018
                              • 1784
                              #15
                              The template documentation says that macros {$TCP.PORT.MATCHES} and {$TCP.PORT.NOT_MATCHES} (regular expressions) can be used for filtering. So, for example, to match only port 22, you could use ^22$ in {$TCP.PORT.MATCHES}. Or, ^(22|443|3306)$ matches 22, 443 or 3306.
                              ^ matches start of string, $ matches end of string. Parenthesis and pipe (|) can be used as "or" grouping.
                              If you enter just 22, it will match any string that contains 22, like 10220. Or, plain (22|443) will match 12200 and 30443.
                              Markku
