IPMI charts and others don't draws. How to make chart draws?
  • sciensys
    • Feb 2020
    • 20
    in most templates, if incoming data the same, and there is works a preprocessing:
    Discard unchanged with heartbeat [period]
    then chart will not draw. It draws as points during the period specified in preprocessing option.
    it's right when the same data are discard, not to clutter up the database!
    so, if I removing preprocessing 'Discard unchanged with heartbeat', then chart draws perfect, but I store to database all time the same data.
    and the question:
    Is it possible to tuneup, to make the chart draws between dots in line ?
  • Hamardaban
    • May 2019
    • 2714
    You may use dashboard widget graph with Missing data=Connected .
    • sciensys
      • Feb 2020
      • 20
      Thanks, I agree this is an option.
      but if charts is a couple of hundred, someone may have a couple of thousand or more .. create them all as dashboard widget is no longer an option.
      Is it possible to specify this option in charts for templates, when type of information is Numeric (unsigned) or Numeric (float) ?
      for now I have to store every 1 or 2 minutes unchanged data for some hundred sensors to get a appropriate charts.
      2022-07-04 21:11:31 3000
      2022-07-04 21:09:31 3000
      2022-07-04 21:07:31 3000
      2022-07-04 21:05:30 3000
      2022-07-04 21:03:31 3000
      2022-07-04 21:01:30 3000
      2022-07-04 20:59:31 3000
      2022-07-04 20:57:32 3000
      2022-07-04 20:55:31 3000
      2022-07-04 20:53:32 3000
      2022-07-04 20:51:31 3000
      2022-07-04 20:49:31 3000
      2022-07-04 20:47:31 3100
      2022-07-04 20:45:31 3000
      2022-07-04 20:43:31 3000
      2022-07-04 20:41:30 3000
      2022-07-04 20:39:32 3000
      2022-07-04 20:37:32 3000
      2022-07-04 20:35:31 3000
      2022-07-04 20:33:31 3000
      2022-07-04 20:31:31 3000
      2022-07-04 20:29:31 3000
      2022-07-04 20:27:31 3000
      2022-07-04 20:25:31 3000
      2022-07-04 20:23:31 3000
      2022-07-04 20:21:31 3000
      2022-07-04 20:19:31 3000
      2022-07-04 20:17:30 3000
      2022-07-04 20:15:36 3000
      2022-07-04 20:13:31 3000
      • Hamardaban
        • May 2019
        • 2714
        For details about the possibilities, it is better to refer to the documentation.
        It has been announced that in the 6.4 versions of Z all graphs will be vector - it remains only to wait.
        • sciensys
          • Feb 2020
          • 20
          ok,
          We will be wait....
          thanks for your attention.
