Trigger based on value and time not working
  • waardd
    • Aug 2014
    • 82
    In our zabbix 1.8 we are having troubles in configuring the right trigger.
    We don't want to be allerted if something happens during the naight so we configured the following trigger:
    {System_AOM:system.run[ls /appl/something/file*/somelog | wc -l].last(0)}>0 & {System_AOM:system.run[ls /appl/something/file*/somelog | wc -l].time(0)}>070000 & {System_AOM:system.run[ls /appl/something/file*/somelog | wc -l].time(0)}<235959
    We thought that with this trigger we would not get any messages between 23:59 and 07:00 but we do get them.
    What is wrong with this trigger?
  • waardd
    • Aug 2014
    • 82
    Is there anybody that can tell me why this trigger is not functioning properly?
    How can i make this works with the time option?
    • glebs.ivanovskis
      • Jul 2015
      • 237
      For example, 034500<235959 - that's why you are getting messages at 3:45 a.m.
      Apparently, you should use ">070000".
      • waardd
        • Aug 2014
        • 82
        But they are both used. See my trigger:
        That is what is troubeling me....
        • glebs.ivanovskis
          • Jul 2015
          • 237
          I can't tell for sure how it works in 1.8.
          • waardd
            • Aug 2014
            • 82
            I changed the trigger to:
            And when you perfom a test (in the trigger define screen after toggle input format) all works well.
            Still i get triggermails at 3:50 or 3:51 am
            Seems to be only at that time.....
