Discovery Key "perf_instance_en.discovery[PhysicalDisk]" building JSON data wrong
  • RaulChiarella
    • Apr 2021
    • 59
    Hello there.
    I have a server (W Server 2022) that when i use the following key "perf_instance_en.discovery[PhysicalDisk]" instead of giving me a correct structured JSON like...
    "[{"{#INSTANCE}":"0 D:"},{"{#INSTANCE}":"1 C:"},{"{#INSTANCE}":"_Total"}]"
    Its giving me the following:
    [{"{#INSTANCE}":"0 C: D:"},{"{#INSTANCE}":"_Total"}]
    Apparently this is only happening on this server - And it is the only W Server 2022 i have.
    Has anyone came across this problem?
    And if yes, whats the solution or alternative?
