Global Macros
  • tmcdon
    • Feb 2016
    Global Macros
    I've been trying to use the {HOST.IP} macro within an sql statement of the Database monitor item.
    SELECT blocked FROM ips LEFT JOIN devices ON ips.device_id=devices.id LEFT JOIN service_locations ON devices.service_location_id=service_locations.id WHERE ip_address = INET_ATON('{HOST.IP}')
    It is not working. If I manually define something such as {$IP} = 10.0.0.1 and use {$IP} instead of {HOST.IP} the sql will function as expected.
    Since the {HOST.IP} macro does not appear to support use within the query is there a way to generate the IP in the query without manually setting up the {$IP} macro on each host. Or is it possible to automatically create the {$IP} macro with the IP of the device as the value?
    Thanks for your help!
    (Edited for Clarity)
