Nested calculated items possible?
  • Jason
    • Nov 2007
    • 431
    I'm trying to write an item that takes the Exchange transaction log drive which I get in getExchangeLogPath and then use that to calculate the space free on the drive for back pressure. The formula gives me an error. Can I next calculated items like this?
    100*(last("vfs.fs.size[last("getExchangeLogPath"),total]")-1536M)/last("vfs.fs.size[last("getExchangeLogPath"),total]")
    I can see that might have too many inverted commas in there, but can't see a way round it...
    Oh on 2.4.7.
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Short answer: no.
    First parameter of trigger function in calculated item syntax must be an existing item key. And things like "last(...)" are not supported in item key parameters.
    If I understand your intentions correctly, you can achieve your goal by turning getExchangeLogPath item into low-level discovery rule and creating an item prototype 100*(last("vfs.fs.size[{#YOURLLDMACRO},total]")-1536M)/last("vfs.fs.size[{#YOURLLDMACRO},total]").
    • Jason
      • Nov 2007
      • 431
      I was coming to the conclusion that might be the only way of doing it. Seems a bit of a sledgehammer to crack a nut scenario though.
      Cheers!
      • Jason
        • Nov 2007
        • 431
        Bah,
        I can't do low level discovery because I already have one that does the filesystems and I get a clash of item names with the vfs.fs part.
        I'll have to re-think.
        • Jason
          • Nov 2007
          • 431
          Got it working eventually, but it's a pain if you've already got a filesystem discovery rule running for other things.
