IF statement in trigger expression
  • bubi92
    • Mar 2019
    • 18
    Eyo Guys!
    I would like to build a new disk space template with some dependency.
    For example:
    IF the full disk size is bigger than 100GB, and there is less then 10GB free space
    OR
    IF the full disk size is smaller than 100GB, and there is less then 5GB free space
    I would like to get an alert.
    I know how to add an "AND" variable.
Name:	Screenshot 2022-07-13 at 13.32.42.png
    My problem is, how to make an IF statement in the expression.
    Gino
  • vladimir_lv
    • May 2022
    • 240
    Regarding documentation, there is no way to use IF statement
    • Hamardaban
      • May 2019
      • 2714
      The entire trigger expression is an IF condition! You don't need anything more
      Here is the trigger expression scheme you need:
      (last(disk_size) >100G and last(free_space)<10G) or (last(disk_size) <100G and last(free_space)<5G)
      • bubi92
        • Mar 2019
        • 18
        Okay. So i translated to my enviroment
        4 new TAG on every windows hosts
        $BIGDISK_UTIL_CRIT=10GB
        $SMALLDISK_UTIL_CRIT=5GB
        $XCH_DISKUTIL_CRIT=12%
        $XCH= X (Is it exchange server or not)
        So first two line: not equal to xch, so if bigger than 100GB will alert under under 10GB and not equal to xch, and smaller than 100GB will alert under 5GB - clear
        In the next lines i would like to define if XCH=X(its an exchange server) check the C drive with percentage, and every other drives with the same metod as the not exchange server drives(if bigger than 100GB will alert under under 10GB - if smaller than 100GB will alert under 5GB)
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[{#FSNAME},total])>100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[{#FSNAME},free])<{$BIGDISK_UTIL_CRIT} and {$XCH}<>"X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[{#FSNAME},total])<100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[{#FSNAME},free])<{$SMALLDISK_UTIL_CRIT} and {$XCH}<>"X"
        or
        last (/Template OS Windows Disk Space Deepblue/vfs.fs.size[C:,pfree])<{$XCH_DISKUTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[D:,total])>100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[D:,free])<{$BIGDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[D:,total])<100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[D:,free])<{$SMALLDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[E:,total])>100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[F:,free])<{$BIGDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[E:,total])<100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[F:,free])<{$SMALLDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[G:,total])>100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[G:,free])<{$BIGDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[G:,total])<100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[G:,free])<{$SMALLDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[H:,total])>100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[H:,free])<{$BIGDISK_UTIL_CRIT} and {$XCH}="X"
        or
        last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[H:,total])<100G and last(/Template OS Windows Disk Space Deepblue/vfs.fs.size[H:,free])<{$SMALLDISK_UTIL_CRIT} and {$XCH}="X"
        This code unfortunately not working, guess the problem is that i defined the drive letters. Is it a syntax or a logical error? What is the correct syntax? Or is there a "smarter", easier way to do this.
        (The final result what i want: Use only one disk template on every windows host and control the triggers with tags)
        (Template OS Windows Disk Space Deepblue is the name of my template)
