Different interface bandwidth utilisation triggers on a device
  • neal.jacob
    • May 2022
    This is my first post, so apologies if it's a newbie question or not in the correct location. We are deploying Zabbix 5.4.10 and want to be able to define different values for network utilisation on a trigger prototype (defined in template 'Template Module Interfaces SNMPv2'). For the vast majority of interfaces on a given device we will utilise one value e.g. 70% (defined as a macro in the template), but for interfaces on the same device that are known to run hot we would like to set an alternate value (e.g. 90%). We have looked into the Override option to filter specific interfaces, but can't see a way to amend the utilisation threshold value for these interfaces without creating a lot of very specific templates. Any assistance would be greatly appreciated.
  • Markku
    • Sep 2018
    • 1784
    Hi, based on https://git.zabbix.com/projects/ZBX/...Frelease%2F5.0 I'd say that you should be able to define macros like {$IF.UTIL.MAX:"GigabitEthernet1/2"} to override the generic macro value based on the interface name. So no need to modify the template, just define those additional macros in the host(s).
    Markku
    • Markku
      • Sep 2018
      • 1784
      (Also note that Zabbix 5.4.x is not officially supported anymore so you should consider using Zabbix 6.0.6 instead)
      • neal.jacob
        neal.jacob commented
        Hi Markku, thanks very much for the feedback, we'll have a look at that. Also take your point on the version. Cheers, Neal.
