Zabbix plugin for Grafana with zabbix 6.0?
  • Plexus
    • Feb 2014
    • 12
    Hi there,
    we are using zabbix 5.4 together with Alexander Zobnin´s grafana-zabbix for quite a while now and I would like to upgrade to zabbix 6.0 soon. Unfortunately refering to Alexander´s documentation compatibility is given up to version 5.x only.
    Has anyone used this combination successfully yet?
    Thanks for your feedback.
    Greetings,
    Plex
  • markfree
    • Apr 2019
    • 872
    I'm testing Zabbix 6.2 and it seems to be working with Grafana's Zabbix Plugin 4.2.9.
    • Hamardaban
      Hamardaban commented
      I confirm this
  • Plexus
    • Feb 2014
    • 12
    Do you have a direct DB connection or are you using the API?
    • Hamardaban
      I use API, not DB connection
    • markfree
      markfree commented
      API as well.
