MSSQL - no data matches the specified path
  • blanguedoc
    • Jul 2022
    I have a problem with the Zabbix MSSQL template it does not give me much data
    Preprocessing failed for: [{"object_name":"IP16","counter_name":"Uptime"," ins tance_name":"","cntr_value":"29275"},{"object_...
    1. Failed: cannot extract value from json by path "$[?(@.object_name=='IP16:Memory Manager' && @.counter_name=='Memory Grants Pending')].cntr_value.first()": no data matches the specified path
    ODBC configuration at Zabbix Proxy level is ok,
    Do you have a solution ?
    Cordialement
    Bastien LANGUEDOC
  • jchavezb
    • Jan 2021
    You must use MSSQL$IP16 in {$MSSQL.INSTANCE}
