How can use ICMPING from second network interface
  • bab
    • Aug 2020
    • 197
    I have a linux host with 2 interface
    eth0 = 10.20.30.40
    eth1= 192.168.20.20
    Now I have added my host with eth0 by agent t o zabbix . Now I need icmping from eth1 to destination "192.168.40.20" How can do this ? because by default i will do icmping from eth0
  • Markku
    • Sep 2018
    • 1784
    You need to configure static route on the host. Commands:
    ip route (shows the routes)
    sudo ip route add 192.168.40.20/32 via <whatever is the next-hop router in the 192.168.20.x network>
    When you get it working, use your favourite search engine to find out how to save that configuration persistently on your Linux distribution.
    Markku
    • bab
      • Aug 2020
      • 197
      Markku
      But I don't want changes on the OS . How can zabbix handle this issue ?
      • Markku
        • Sep 2018
        • 1784
        IP routing on the host is something that Zabbix cannot do as that's the host networking stack that decides that.
        Markku
        • bab
          • Aug 2020
          • 197
          Markku
          But I though there is a template such as icmping that we can also define source in addition destination
          • Markku
            • Sep 2018
            • 1784
            Please do tell us if you find a Zabbix-level solution (without touching the OS). For the record, there is the documentation for icmpping item: https://www.zabbix.com/documentation.../simple_checks
            Markku
