How to display data on Dashboard
  • feniss
    • Jul 2022
    Hi Zabbix Community,
    I followed a guide that enabled me to gather Windows Updates info from my servers and have this data available on Zabbix. I have two stats available, 'Days Since Last Windows Update' and 'Count Outstanding Windows Updates', both in the form of integer number.
    How would you display this on a dashboard? In its simplest form, I envisioned a table with three columns: |Server Name|Days Since Last|Outstanding Windows Updates|
    I'm struggling with the available widgets and how to visualize this on the dashboard. How would you do it?
  • Hamardaban
    • May 2019
    • 2714
    Try using the top hosts widget.
    • feniss
      • Jul 2022
      I followed a guide that enabled me to gather Windows Updates info from my servers and have this data available on Zabbix. I have two stats available, 'Days Since Last Windows Update' and 'Count Outstanding Windows Updates', both in the form of integer number router login.
      I got this,...
