Zabbix agent show confusing messages
  • miramira007
    • Sep 2015
    • 89
    Hellau out there,
    i have some issue with my zabbix agent on linux! During i can monitor services on windows without any problems with service_state[servicename]. On Linux i have some troubleshoot. I created some Userparameter:
    UserParameter=service.check[*], systemctl status $1 | grep -c running
    When I'm testing "systemctl status $1 | grep -c running" in the terminal on my linux maschine i'm get 1 (service is running, 0 for all other options)
    But in my front-end, i'm getting 0!
    Short summary: The expression on the terminal is giving me a right return, but on the front-end i'm getting 0 and this is not the true! (zabbix agent is lying to me )
    Do someone have an idea?
  • Firm
    • Dec 2009
    • 342
    Check zabbix_agentd.log. Probably, zabbix can't run systemctl.
    • miramira007
      • Sep 2015
      • 89
      on another host (on centos) it works fine. even with systemctl. both services are running on a centos machine. it must be another issue. another idea?
      • Atsushi
        • Aug 2013
        • 2028
        What is the CentOS version of the environment which you cannot get real value?
        For example, systemd is not available on CentOS 6 by default.
        systemd is available on CentOS 7.
        Please tell me the CentOS version of do not work environment.
        • miramira007
          • Sep 2015
          • 89
          In our environment we have centos 7 or redhat 7,6 (64bit version). but im confisud about the effect, that if i run the line "systectl status service | grep -c running" in the terminal. it gives me the right value. from the agent, trought the zabbix agent, it returns me a wrong value.
          i tried to check the user rights: zabbix has the rights to execute all.
          but if the agent cant systemctl, why it returns me a value? Shouldn't i get some error message??
          cu,mira
          • Firm
            • Dec 2009
            • 342
            What is the output of
            su - zabbix -c 'systemctl status <process_name> | grep -c running'
            • miramira007
              • Sep 2015
              • 89
              Hellau,
              im getting this error message
              su: warning: cannot change directory to /var/lib/zabbix: No such file or directory
              This account is currently not available.
              What does it mean? On this host my UserParameter is running and the agent gives a right value. On the other hosts i haven't got any rights. This is my test server with centos7 and here does everything fine
              cu, mira
              • Atsushi
                • Aug 2013
                • 2028
                I think that can not be used systemctl command on RHEL 6.
                • miramira007
                  • Sep 2015
                  • 89
                  Yes i know it, systemctl is not supported in centos6. im talking about the centos7. if someone have another idee to monitor linux services, no such as "systemctl status service | grep -c running"- i liked this command much, because, it just gives me a 0 or a 1(running). I want to get such a result. But you can tell me, how you handle this.
                  cu, mira
                  • michaelwemoto
                    • Apr 2016
                    I'm seeing the same issue with CentOS7.2, Disabling selinux allows this to work. I'm having great difficulty building a custom selinux policy that allows zabbix to use systemctl for all unit files;
                    zab-client;
                    cat /etc/zabbix/zabbix_agentd.d/custom.conf
                    UserParameter=custom.service.check[*],if systemctl status $1 | grep running >> /dev/null; then echo 0; else echo 1; fi
                    zab-server;
                    zabbix_get -s 192.168.59.186 -k "custom.service.check[httpd]"
                    sh: /usr/bin/systemctl: Permission denied
                    1
                    zab-client;
                    setenforce 0
                    zab-server;
                    [root@zabbix-server ~]# zabbix_get -s 192.168.59.186 -k "custom.service.check[httpd]"
                    1
                    [root@zabbix-server ~]# zabbix_get -s 192.168.59.186 -k "custom.service.check[crond]"
                    0
                    [root@zabbix-server ~]# zabbix_get -s 192.168.59.186 -k "custom.service.check[postfix]"
                    0
                    [root@zabbix-server ~]# zabbix_get -s 192.168.59.186 -k "custom.service.check[firewalld]"
                    0
                    zab-client;
                    audit2allow -a
                    #============= init_t ==============
                    allow init_t zabbix_agent_t:dbus send_msg;
                    #============= zabbix_agent_t ==============
                    allow zabbix_agent_t cgroup_t:file { read open };
                    allow zabbix_agent_t crond_unit_file_t:service status;
                    allow zabbix_agent_t firewalld_unit_file_t:service status;
                    allow zabbix_agent_t init_t:dbus send_msg;
                    allow zabbix_agent_t init_t:service status;
                    allow zabbix_agent_t system_dbusd_t:dbus send_msg;
                    allow zabbix_agent_t system_dbusd_t:unix_stream_socket connectto;
                    allow zabbix_agent_t system_dbusd_var_run_t:sock_file write;
                    allow zabbix_agent_t systemd_systemctl_exec_t:file execute_no_trans;
                    allow zabbix_agent_t systemd_unit_file_t:service status;
                    audit2allow -a -M zab
                    semodule -i zab.pp
                    setenforce 1
                    and now the services I tried to check while selnux was not enforcing are fine. I need to allow ALL unit_file_t:service status, this is where I am stuck.
                    any suggestions?
                    • michaelwemoto
                      • Apr 2016
                      Problem solved;
                      client -
                      # reset your log so you only catch the warnings that we want
                      echo "" > /var/log/audit/audit.log
                      setenforce 0
                      server -
                      zabbix_get -s 123.456.789.1 -k "custom.service.check[firewalld]"
                      0
                      client-
                      cat /var/log/audit/audit.log | audit2allow -M zabbix-firewalld
                      semodule -i zabbix-firewalld.pp
                      setenforce 1
                      That policy will allow firewalld service status alone, I made a policy for each service I required and will only apply them where needed.
                      After running the above command and inspecting the zabbix-firewalld.te there are a lot of entries for just systemctl and not specifically firewalld.
                      I repeated the process above for another service and then split my policies;
                      cat zabbix-systemctl.te
                      module zabbix-systemctl 1.0;
                      require {
                      type cgroup_t;
                      type system_dbusd_var_run_t;
                      type init_t;
                      type systemd_systemctl_exec_t;
                      type zabbix_agent_t;
                      type system_dbusd_t;
                      class sock_file write;
                      class unix_stream_socket connectto;
                      class dbus send_msg;
                      class file { read execute open execute_no_trans };
                      class service status;
                      allow zabbix_agent_t systemd_systemctl_exec_t:file { execute execute_no_trans };
                      cat zabbix-firewalld.te
                      module zabbix-firewalld 1.0;
                      require {
                      type firewalld_unit_file_t;
                      cat zabbix-postfix.te
                      module zabbix-postfix 1.0;
                      require {
                      type systemd_unit_file_t;
                      cat zabbix-httpd.te
                      module zabbix-httpd 1.0;
                      require {
                      type httpd_unit_file_t;
                      allow zabbix_agent_t httpd_unit_file_t:service status;
                      after creating the *.te files you follow this process to compile into a selinux policy;
                      checkmodule -M -m -o zabbix-systemctl.mod zabbix-systemctl.te
                      semodule_package -o zabbix-systemctl.pp -m zabbix-systemctl.mod
                      semodule -i zabbix-systemctl.pp
                      replacing the file names as appropriate.
                      I hope this helps someone out, I spent a week trying to solve this.
