API connection is not working
  • b3owu1f
    • Mar 2022
    Greetings everyone,
    I'm trying to connect to Zabbix through API but it seems I can't get anything done. All forms I tried result in errors, even from inside the server. I tried many ways to retrieve apiiversion and to use user.login.
    My frontend is at http://192.168.0.100/zabbix
    I did not install the frontend. It was given to me to work on. Can it be any issue with the installation? There's anything I need to configure?
    Zabbix version is 5.0.16 and the api files are found on following places:
    # find . -name api_jsonrpc.php
    ./opt/zabbix-backup/zabbix/api_jsonrpc.php
    ./opt/comp/zabbix-5.0.16/ui/api_jsonrpc.php
    ./usr/share/zabbix/api_jsonrpc.php
    I tried using curl from inside the server, to localhost and real IP, didn't work:
    curl -s -X POST -H 'Content-Type: application/json-rpc' -d '{"jsonrpc":"2.0","method":"apiinfo.version","id ": 1,"auth":null,"params":{}}' 'http://127.0.0.1/zabbix/api_jsonrpc.php'
    curl -s -X POST -H 'Content-Type: application/json-rpc' -d '{"jsonrpc":"2.0","method":"apiinfo.version","id ": 1,"auth":null,"params":{}}' 'http://192.168.0.100/zabbix/api_jsonrpc.php'
    And results are:
    <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
    <html><head>
    <title>302 Found</title>
    </head><body>
    <h1>Found</h1>
    <p>The document has moved <a href="https://127.0.0.1/api_jsonrpc.php">here</a>.</p>
    </body></html>
    I tried through Postman app too:
    POST http://192.168.0.100/zabbix/api_jsonrpc.php
    Headers:
    Body: raw
    "jsonrpc":"2.0",
    "params":{},
    "id":1
    And results are:
    <html>
    <head>
    <title>400 Bad Request</title>
    </head>
    <body>
    <h1>Bad Request</h1>
    <p>Your browser sent a request that this server could not understand.<br/>
    </p>
    </body>
    </html>
  • Markku
    • Sep 2018
    • 1784
    302 Found
    So, is it http or https?
    Your Postman test is missing the auth field, if that matters.
    To be sure, the documentation is: https://www.zabbix.com/documentation/5.0/en/manual/api
    Markku
    • b3owu1f
      b3owu1f commented
      When I access the frontend it shows https. I tried the CURL either way with http and https. https returns nothing.
      The spaces are being added by the forum. there's no spaces in the CURL.
      [root@zbx ~]# curl -s -X POST -H 'Content-Type:application/json' -d '{"params":{},"jsonrpc":"2.0","method":"apiinfo.ve rsion","id":1,"auth":null}' 'http://127.0.0.1/zabbix/api_jsonrpc.php'
      <html><head>
      </head><body>
      <h1>Found</h1>
      <p>The document has moved <a href="https://127.0.0.1/zabbix/api_jsonrpc.php">here</a>.</p>
      </body></html>
      [root@zbx ~]# curl -s -X POST -H 'Content-Type:application/json' -d '{"params":{},"jsonrpc":"2.0","method":"apiinfo.ve rsion","id":1,"auth":null}' 'https://127.0.0.1/zabbix/api_jsonrpc.php'
      [root@zbx ~]#
    • Markku
      Markku commented
      -s option "hides" the certificate error from curl.
  • vladimir_lv
    • May 2022
    • 240
    Just remove space after id and before 1
    • Markku
      Markku commented
      This forum software is such a piece of fine art that it sometimes adds spaces of its own, you never know... worth pointing out anyway.
      Markku
    • b3owu1f
      b3owu1f commented
  • Markku
    • Sep 2018
    • 1784
    Just testing: with the incorrect "id " parameter there is a specific message about the error:
    $ curl -s -X POST -H 'Content-Type: application/json-rpc' -d '{"jsonrpc":"2.0","method":"apiinfo.version","id ": 1,"auth":null,"params":{}}' http://192.168.7.15/zabbix/api_jsonrpc.php
    {"jsonrpc":"2.0","error":{"code":-32600,"message":"Invalid request.","data":"Invalid parameter "/": unexpected parameter "id "."},"id":null}
    Without the space:
    $ curl -s -X POST -H 'Content-Type: application/json-rpc' -d '{"jsonrpc":"2.0","method":"apiinfo.version", "id": 1,"auth":null,"params":{}}' http://192.168.7.15/zabbix/api_jsonrpc.php
    {"jsonrpc":"2.0","result":"6.2.0","id":1}
    (ha, had to add an extra space to separate the parameters because the forum insisted on adding incorrect space otherwise)
    Markku
    • Markku
      • Sep 2018
      • 1784
      I'm (using 6.2.0) not able to get any 400 error with the inputs you showed us. Are you sure that your Zabbix frontend is in that address and not actually somewhere else? (Or, are you sure you used Postman properly)
      Markku
      • b3owu1f
        b3owu1f commented
        Yes I'm sure it's the frontend, I access it normally. Not so sure I'm using the POSTMAN correctly, I just followed a tutorial since the CURL wasn't working. I did try with either http and https and same result.
    • b3owu1f
      • Mar 2022
      There's no space in the CURL. Idk why the forum added it when pasting here.
      I keep trying every tutorial I find and I can't get it to work. I really need it to. So any help is very much appreciated.
      • b3owu1f
        • Mar 2022
        After you mentioned this, I remembered the server has no valid certificate for https as it says it's not safe connection. So I started looking around about Zabbix API on HTTPS and found this https://www.zabbix.com/forum/zabbix-...-api-via-https
        All the issue seems about not having a valid certificate on https. So I went to apache httpd.conf and removed the forcing http to https, and now I get data normally from the CURL on http.
        #RewriteEngine On
        #RewriteCond %{HTTPS} off
        #RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
        Thanks for the insight. I hope this can help others who stumble upon this. I think this matter is finished.
        • Markku
          • Sep 2018
          • 1784
          Yes so using (properly configured) self-signed certificate for encryption is not a problem with Zabbix API. Just make sure that the client can handle the situation or trust the self-signed certificate.
          Markku
