Zabbix action - Not sending the same data it collects?
  • Nugse
    • Jul 2022
    I have setup Zabbix to monitor Windows Event Log and trigger when specific events are found. This is working as it should, and under latest data i see all the events.
    In Zabbix i created an action to send a mail each time the event is triggered, this is also working. EXCEPT, when the trigger is catching multiple events on the same time, the action sends the last event multiple times instead of the different events.
    So the issue is that all data is collected correctly within Zabbix, but as soon as multiple events has been triggered on the exact same time, the action sends the last event triggered, instead of the different events. Within the action panel it even states different problem ID's.
    How exactly would i go on fixing this? It seems to be a bug between the data Zabbix has gathered and the action feature?
