Require assistance
  • docofchaos
    • Feb 2016
    Require assistance
    Hello here,
    I search a several hours to find an issue with my log monitoring
    I want to check a log file and find a string : I use to
    log["/var/log/sync.log","Modify"]
    it works fine, in history of zabbix server i can see this
    2016-02-23 23:09:25 - 2016-02-23 20:45 Modify file to server with id xxx
    little example of my regular file
    2016-02-22 21:09:25 Modify file to server with id 13250
    2016-02-22 21:19:15 Modify file to server with id 14505
    2016-02-22 23:09:55 Delete file to server with id 12543
    2016-02-22 23:13:32 Add file to server with id 17256
    But my trigger has a little problem, they send me all the line who contains "modify" and can recover the severity.
    When i'll test my trigger the server send 1500 mail
    I'll try many expression to send a mail if the string will found.
    if you have many idear i'm stuck
    sorry for my bad english i'm french but i understand very well
  • Firm
    • Dec 2009
    • 342
    Show trigger expression.
    • docofchaos
      • Feb 2016
      hi, this is my trigger
      {Template OS Proxmox:log["/var/log/sync.log","Modify"].str()}=1
      {Template OS Proxmox:log["/var/log/sync.log","Modify"].nodata(20)}=0
      {Template OS Proxmox:log["/var/log/sync.log","Modify"].abstract()}=0
      i used manu combinaison of them but don't work, or I have got 3 mail per occurence
