zabbix 2.4 graph not showing all interfaces
  • tomindo
    • Feb 2016
    HI guys,
    I ran this from zabbix server, there is the output
    zabbix_get -s 192.168.16.237 -k net.if.discovery
    {"data":[{"{#IFNAME}":"lo"},{"{#IFNAME}":"eth0"},{"{#IFNAME }":"eth1"}]}
    but it only shows graph for lo
    I have reduced the network discovery to 1 seconds but not luck
    any idea?
    Mike
  • Firm
    • Dec 2009
    • 342
    Check if metrics were created and data are collected.
    • tomindo
      • Feb 2016
      Hi
      Can you tell me how to check if metrics were created and data are collected.
      • Firm
        • Dec 2009
        • 342
        Discovery rule should create metrics for interfaces it discovered. Check in Latest data if metrics emerged.
        • tomindo
          • Feb 2016
          there is no key_: net.if.in[eth0] and data in database but lo loopback.
          Data for eth0 and eth1 got deleted somehow , it was working fine before.
          any other ideas ? or how to rebuild the database ?
          thanks
          • Firm
            • Dec 2009
            • 342
            Try to unlink template and attach it again.
            • tomindo
              • Feb 2016
              I have tried that, even added new host but it only shows lo interface.
              any other ideas ?
              thanks
              • tomindo
                • Feb 2016
                the log shows zabbix server still collects data for other interfaces but it just dont show up on the UI .
                6026:20160302:111856.323 get value from agent result: '{"data":[{"{#IFNAME}":"lo"},{"{#IFNAME}":"eth0"},{"{#IFNAME }":"eth1"},{"{#IFNAME}":"eth2"},{"{#IFNAME}":"eth3 "}]}'
                6023:20160302:111856.323 In lld_make_item()
                6026:20160302:111856.323 End of get_value_agent():SUCCEED
                6023:20160302:111856.323 In substitute_key_macros() data:'net.if.in[{#IFNAME}]'
                6026:20160302:111856.323 End of get_value():SUCCEED
                6023:20160302:111856.323 In substitute_discovery_macros() data:'{#IFNAME}'
                6026:20160302:111856.323 In activate_host() hostid:10126 itemid:25778 type:0
                6023:20160302:111856.323 End of substitute_discovery_macros():SUCCEED data:'lo'
                6026:20160302:111856.323 End of activate_host()
                6023:20160302:111856.323 End of substitute_key_macros():SUCCEED data:'net.if.in[lo]'
                6026:20160302:111856.323 In lld_process_discovery_rule() itemid:25778
                6023:20160302:111856.323 In substitute_discovery_macros() data:'Incoming network traffic on $1'
                6026:20160302:111856.323 query [txnlev:0] [select hostid,key_,state,evaltype,formula,error,lifetime from items where itemid=25778]
                6023:20160302:111856.323 End of substitute_discovery_macros():SUCCEED data:'Incoming network traffic on $1'
                • Firm
                  • Dec 2009
                  • 342
                  Check Filter tab in discovery rule.
                  • tomindo
                    • Feb 2016
                    This is what the filter looks like
                    Macro Regular Expression
                    {#IFNAME} @Network interfaces for discovery
                    This is default value I think
                    thanks
                    • Firm
                      • Dec 2009
                      • 342
                      Try to remove filter and check what happens.
                      • tomindo
                        • Feb 2016
                        ah that did the tricks. All interfaces show now
                        thanks
