Is it possible to use a MACRO inside of a MACRO?
  • r0k
    • May 2020
    we just added the certificate monitoring template to a host. we already use a web monitoring template which works fine. For the cert monitoring template we need to adjust the {$CERT.WEBSITE.HOSTNAME} MACRO. Since we want to use the template on multiple hosts it would be great if we could use something like:
    {$CERT.WEBSITE.HOSTNAME} -> {HOST.CONN} as a default in the template. Somehow we can't get it to work, so the general question would be is it even possible to have a MACRO as a value of another MACRO?
    Best Regards,
    Oliver
