Get problem directly on Zabbix Proxy
  • andarius40
    • Jul 2022
    Good afternoon,
    Currently I run some test with Zabbix 5.0.19 (I will be upgrade it to 6 LTS ) soon
    My question is
    If I have a mistake between Zabbix proxy and Zabbix Server.
    is it possible to get problem on Zabbix proxy direclty, maybe with api or a SLQ request
    I have test a SQL request :
    SELECT p.clock, p.value, p.itemid, i.itemid,i.name, i.key_ , i.status, i.hostid, h.hostid, h.host, h.name, h.status
    FROM pr
    oxy_history p
    INNER JOIN items i ON ( i.itemid = p.itemid )
    INNER JOIN hosts h ON (i.hostid = h.hostid)
    WHERE p.value <> 0
    LIMIT 50;
    But I don't find parameter or maybe a table missing, to obtain last 50 alerts
    Thank you for your help
    Best Regards
  • Markku
    • Sep 2018
    • 1784
    My question is
    See the documentation: https://www.zabbix.com/documentation...toring/proxies
    Markku
    • andarius40
      • Jul 2022
      Good morning,
      Thank you.
      I understand, it's not possible.
      Best Regards
