Hello!
I want to make trigger dependencies on template basis or something like that.
My scenario in short:
I have about 35 remote locations (monitored directly from the zabbix server via VPN).
Each has a Modem, Router, and then about 5-10 devices directly connected to the router.
The modem is the most central point in terms of Internet Access. If this device fails all devices will be unavailable. The router is the next central point and the clients are all connected directly to the router.
So my Trigger Dependency would look like this:
Location 1:
Now, I would have to set each trigger on each device to be dependent from the router and the router itself from the modem.
And this I would have to repeat 35 times for each remote location. And if devices are added in the future, I'd have to make them manually dependent again.
Isn't there a faster way? I can't believe that guys with about 1000+ devices do this all by hand.
Thanks in advance
Andreas
Location 1:
| Modem | ||||
| Router | ||||
| Device1 | Device2 | Device3 | Device4 | Device5 |
Thanks in advance
Andreas
