about "VMWare SD-WAN VeloCloud SNMP" template
  • syman888
    • Jul 2022
    • 12
    hi eveybody,
    I want to monitor the network traffic of my SDWAN device. I want to set the network usage traffic to trigger a warning when 80% of the traffic is fully loaded, and trigger a serious trigger when it is fully loaded at 90%. Is there a template that can be downloaded? I use SNMP v2 to obtain data. I have tested and installed the "VMWare SD-WAN VeloCloud by HTTP" template of zabbix 6 before, but I will not set it. Currently my version is zabbix 5, thank you
  • syman888
    • Jul 2022
    • 12
    Hopefully zabbix will have a "VMWare SD-WAN VeloCloud SNMP" template
