SNMPv3 : SNMP error
  • Cloudeuw
    • Jul 2022
    • 11
    SNMPv3 : SNMP error
    I have a problem with a device that uses SNMPv3. Zabbix tells me that SNMPv3 is available (so the different configurations are well done) screen below.
    But when I start to retrieve some OIDs, it tells me: SNMP error: authorizationError (access denied to that object)
    However, when I run the snmpwalk command directly on the same server, I manage to retrieve the OID I want.
    Zabbix logs inform me that the equipment is available:
    Someone would have any idea ? I don't think it comes from the equipment since I manage to recover the OID. I have several devices in SNMPv3 and this problem does not occur. It is only on this equipment that I have the concern.
    I'm on version 6.2 but on version 6.0 it was already giving me the problem.
  • vladimir_lv
    • May 2022
    • 240
    Hi!
    Are you using the same authentication protocol on both sides (device and Zabbix)?
    • Cloudeuw
      • Jul 2022
      • 11
      Yes, I have several devices in SNMPv3 with the same authentications and for the others I have no worries.
      • Cloudeuw
        • Jul 2022
        • 11
        Example log
        item "XXXX[ifSpeed.532480]" became not supported: SNMP error: authorizationError (access denied to that object)
