database upgrade still says no
  • wiliamL
    • Feb 2022
    • 28
    Upgraded from 4.2.7 to 5.0.23
    MySQL - 5.7.28
    Ran the double.sql and the site is stating No for Database history tables upgraded.
    https://git.zabbix.com/projects/ZBX/...sql/double.sql
    mysql> ALTER TABLE trends
    -> MODIFY value_min DOUBLE PRECISION DEFAULT '0.0000' NOT NULL,
    -> MODIFY value_avg DOUBLE PRECISION DEFAULT '0.0000' NOT NULL,
    -> MODIFY value_max DOUBLE PRECISION DEFAULT '0.0000' NOT NULL;
    Query OK, 0 rows affected (0.00 sec)
    Records: 0 Duplicates: 0 Warnings: 0
    mysql> ALTER TABLE history MODIFY value DOUBLE PRECISION DEFAULT '0.0000' NOT NULL;
    Any help greatly appreciated
  • Answer selected by Markku at 27-07-2022, 19:23.
    Markku
    • Sep 2018
    • 1786
    See the documentation: https://www.zabbix.com/documentation...c-float-values
    After upgrading database tables, please also set or update $DB['DOUBLE_IEEE754'] value to true in /ui/conf/zabbix.conf.php.
    Usual location for the file is /etc/zabbix/web/zabbix.conf.php.
    Markku
    • Markku
      • Sep 2018
      • 1786
      Markku
      • wiliamL
        • Feb 2022
        • 28
        Thank you. Not sure how I overlooked that.
