get more line with log monitoring
  • alescri
    • May 2019
    • 32
    hello,
    i saw an ol post about regular expression and log monitoring,
    i have some trouble with it.
    actually my log file is something like that:
    Explore and test this PCRE2 (PHP) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
    i found a regular expression that catch more lines but i can't view it on zabbix latest data ,
    the item is:
    log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,"(.*[[:space:]]GRAVE:.*)",,,,\1]
    i tried to change the information type to log to text, but i still don't see anything in latest data,
    where I'm wrong?
    hope you can help me,
    thanks
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    The Type of information of the item with key log must be set to Log (otherwise it won't work). If you want to catch the whole line you can just go with
    log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,"[[:space:]]GRAVE:"]
    or, if you want to catch all after "GRAVE":
    log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,"[[:space:]](GRAVE:.*)",,,,"\1"]
    It looks like your issue might be that the output is not double-quoted.
    • alescri
      • May 2019
      • 32
      my idea is to havein latest data the complete log info like
      lug 26, 2022 10:30:25 PM org.zkoss.zk.ui.http.WebManager <init>:179
      GRAVE: File not found: file:///workarea/apache-tomcat/tomcatGA/confapps/GestioneAutorizzazioni/zk-production.xml
      i tried your regexp but it doesn't work,
      actually this one give me back a latest data but i loose some information
      log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,GRAVE,,,,]
      in regex101 your regex works but zabbix's latest data are blank
      we use zabbix version 5.2.7
      any ideas?
      • alescri
        • May 2019
        • 32
        (.*[[:alpha:]] [[:alnum:]].*\nGRAVE.*)
        works on regexp101 but not on zabbix
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          And this one:
          log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,"\sGRAVE:"]
          • Markku
            • Sep 2018
            • 1784
            Does using multiline option (https://www.pcre.org/current/doc/htm...tax.html#SEC16) (?m) change something? I mean, in regex101 it is set (the "m" in "gm").
            Markku
            • Hamardaban
              • May 2019
              • 2714
              Multiline is not supported in log regex at zabbix.
              Each line is processed separately!
              As Markku wrote….
              • alescri
                • May 2019
                • 32
                And this one:
                neither... as other member wrote probably multiline is not supported ....
                • alescri
                  • May 2019
                  • 32
                  As Markku wrote….
                  thanks i hope it will be implemented
                  • dimir
                    Zabbix developer
                    • Apr 2011
                    • 1080
                    Oh man, you have endline there (\n), correct, line by line only, currently...
                    In your case I'd just go with the
                    log[/workarea/apache-tomcat/apache-tomcat-7.0.47_GA/logs/catalina.out,"^GRAVE:"]
                    Note, "^" means the beginning of the line.
