Hi I've just installed zabbix 3.0.
it as worked very well I think.
I've notices some problems though regarding SNMP devices.
I did create a discovery rule as in zabbix 2.4 and a particular test device was consequently discovered as aspected. Very good :-)
But when linking templates and gathering data, I get no data.
I did this as in zabbix 2.4 but now it does'nt work. I'm trying to find what has changed regarding i.e. SNMP_Commnunity string etc between those versions 2.4 and 3.0 .
Any good input from you, that could explain my troubles now?
this is from the log file,
/var/log/zabbix/zabbix_server.log
1375:20160226:101508.650 item "lab-7201:ciscoFlashDeviceDescr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1375:20160226:101508.650 item "lab-7201:ciscoMemoryPoolName" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1375:20160226:101508.650 item "lab-7201:cpmCPUTotalPhysicalIndex" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
spfNbrIpAddr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1374:20160226:101508.658 item "lab-7201:bgpPeerIdentifier" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1374:20160226:101508.658 item "lab-7201:ciscoEnvMonFanStatusDescr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1374:20160226:101508.658 item "lab-7201:ciscoEnvMonSupplyStatusDescr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1374:20160226:101508.658 item "lab-7201:ciscoEnvMonTemperatureStatusDescr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
1374:20160226:101508.658 item "lab-7201:ciscoEnvMonVoltageStatusDescr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
spfIfIpAddress" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
best regards
Yngvi
spfNbrIpAddr" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.1374:20160226:101508.658 item "lab-7201:bgpPeerIdentifier" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.
spfIfIpAddress" became not supported: Invalid SNMP OID: pairs of macro and OID are expected.best regards
Yngvi
