traceroute / ping / nmap missing from zabbix-proxy-sqlite3
  • bitbucket
    • Sep 2020
    • 18
    Is this an oversight or intentional? I guess you could deploy a separate agent on the proxy host but this seems counterintuitive since problems are sourced from proxies (and users expect to right-click on the problem and have the ability to run basic diagnostics). fping is present but that leaves traceroute and nmap capabilities unaccounted for.
  • Markku
    • Sep 2018
    • 1784
    It is up to the server administrator to install any additional packages that he/she wants to use. traceroute/ping/nmap commands are not used by Zabbix.
    Markku
    • bitbucket
      • Sep 2020
      • 18
      Zabbix comes pre-configured with ping / traceroute / and OS detect (nmap) functions. These functions depend, out of the box, on the corresponding utilities. How can you say they're not used by zabbix? Also, installing additional utilities in a docker environment is a non-trivial thing. Since zabbix is shipped with a traceroute script....the docker images should have traceroute.
      • Markku
        • Sep 2018
        • 1784
        Oh, those, yeah, never used those example scripts. Feel free to open an enhancement request in https://support.zabbix.com if you like. They still are external packages that are not used by Zabbix itself.
        Markku
        • bitbucket
          • Sep 2020
          • 18
          Looks like someone beat me to it.... https://github.com/zabbix/zabbix-docker/issues/983
