Trigger looking for package installed using key system.sw.packages
  • josesilva
    • Feb 2020
    Hi im trying to config a trigger that check when an specific package its installed.
    Using the system.sw.packages im getting the pakcage list in server. But when i try to create the trigger for this using find parameter, the result is nothing.
    This is the config im using:
    find(/server/system.sw.packages,#1,"like","net-tools")=0
    If a server doesnt have any version of net-tools installed the trigger should report error, right now im not receiving anything.
    Thanks for your help.
  • vladimir_lv
    • May 2022
    • 240
    Hi!
    Your expression looks as correct. Is something going wrong?
