How to auto discovery folders?
  • Lake
    • Feb 2016
    I am new with Zabbix.
    I try to monitor file flows.
    I got files to date-folders.
    So I try discovery my sub-folders.
    path
    sub-folder-1
    date-folder-1
    date-folder-2
    sub-folder-2
    date-folder-1
    date-folder-2
    sub-folder-3
    date-folder-1
    date-folder-2
    sub-folder-20
    date-folder-1
    date-folder-2
    My script is returning delta time.
    ./script.py sub-folder-1
    #!/usr/bin/python
    import os
    import datetime
    import sys
    def file_modification_date(fname):
    t = os.path.getmtime(fname)
    return datetime.datetime.fromtimestamp(t).strftime('%s')
    def ReadDir(basedir):
    l = 0
    filetime = 0
    if os.path.isdir(basedir):
    ct = int(datetime.datetime.now().strftime('%s'))
    filetime = file_modification_date(max([os.path.join(basedir,d) for d in os.listdir(basedir)], key=os.path.getmtime))
    if len(str(ct - int(filetime))) > l:
    l = str(ct - int(filetime))
    return int(l)
    ### Main ###
    path = "/data/path/"
    if len(sys.argv) <> 2:
    exit()
    path = path + sys.argv[1]
    print ReadDir(path)
  • Firm
    • Dec 2009
    • 342
    You need to output JSON-format for discovered folders.
    Add the following to zabbix_agentd configuration:
    UserParameter=folder.discovery[*],/usr/bin/find $1 -maxdepth $2 -type d| /usr/bin/awk 'BEGIN {first=1; printf "%s","{\"data\":["} {if (first != 1) printf "%s",","; first=0; printf "{\"{#FOLDER_NAME}\":\"%s\"}",$$1} END {print "]}"}'
    Use like:
    folder.discovery[/data/top-folder,1]
    You can monitor mtime of items then.
    • Lake
      • Feb 2016
      Thank you Firm.
      This was helping me a lot.
      //Lake
