ODBC Get - switch Database
  • Zablab
    • Jan 2022
    • 28
    I'm unable to find how to use a specific Database using the db.odbc.get key.
    I'm using the Database Monitor and passing a Query to SQL. It works well enough, but it seems I cannot switch Databases.
    For example, I receive "[]" if I execute the following query, which should be returning some Data.
    USE tempdb;
    SELECT TOP (1) [object_id]
    ,[name]
    FROM [tempdb].[sys].[all_columns]
    Is it possible to switch between Databases?
    With appreciation,
  • Zablab
    • Jan 2022
    • 28
    Update:
    Although it would be nice to do this in the query and if anybody has a better idea, I'd greatly appreciate it!
    As a workaround, or perhaps this is how things are, I created a specific DSN\Database connection in my ODBC.ini that I use in the Zabbix template.
