How to monitor iptables rules' count with zabbix
  • dsilenco
    • Aug 2022
    hey all, how can i monitor my Ubutnu iptables rule count and if reaches some limit it will restart the service. Here is what i did:
    zabbix.agent:
    UserParameter=iptables.rule.count[*],sudo iptables --list --line-numbers | grep DROP | wc -l
    item;
    Key: iptables.rule.count[*]
    Type: Numeric (unassigned)
    Trigger:
    {vgw1-stag:iptables.rule.count[*].count(30)}>1
    No error. Enabled but doesn't do anything.
    Thank you
  • Hamardaban
    • May 2019
    • 2714
    Try running this command as a zabbix user.
    Try to specify the full paths to wc, grep, etc.
