How to install Zabbix
  • Pedro Costa
    • Aug 2022
    Hi everyone!
    I'm having the following issues trying to get Zabbix to work:
    -Install Zabbix using docker containers. Add SNMP Hosts. They're not avaliable.
    If i try the packages, it tries to install 2 different versions of the same packages.
    If i manually install a version, some package will give an error because of the other version.
    If i try to use the Appliance, VCenter can't import it.
    If i try to install via the ISO, the instraller won't even start in EFI mode.
    Changing to BIOS mode, it does start but gets stuck.
    Changing further the disk from SCSI to SATA the installer goes further, but still gets stuck.
    It seems Zabbix is designed to not be able to install...
    Has anyone managed to this to work?
    I use ESXi 7.0.1 + Rocky Linux 9
    Cheers!
  • LenR
    • Sep 2009
    • 1011
    Vultr Rocky Linux release 8.6 Zabbix 6.0 upgraded to 6.2 followed https://www.zabbix.com/documentation..._from_packages
    • DaLoZ
      • Aug 2022
      • 25
      I installed AlmaLinuxOS on ESXI 6.7 and followed the guide on the Zabbix website and worked just fine.
      Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
      • lkf_mabe
        • Aug 2022
        Originally posted by Pedro Costa
        Hi everyone!
        Cheers!
        Try using the Intel E1000 network card driver
        • lkf_mabe
          • Aug 2022
          Now at the moment I'm trying to install on esxi 6.5, it's not installed. On esxi 6.7 it was established without problems.
