How to install zabbix agent on XCP-ng 8.1.0
  • Ostad
    • Jul 2022
    • 10
    does anyone have an idea how I can install zabbix agent on Xenserver with XCP-ng OS?
    HTML Code:
    # cat /etc/os-release
    NAME="XCP-ng"
    VERSION="8.1.0"
    ID="xenenterprise"
    ID_LIKE="centos rhel fedora"
    VERSION_ID="8.1.0"
    PRETTY_NAME="XCP-ng 8.1.0"
    ANSI_COLOR="0;31"
    HOME_URL="http://xcp-ng.org/"
    BUG_REPORT_URL="https://github.com/xcp-ng/xcp"
    HTML Code:
    # uname -a
    Linux xen1 4.19.0+1 Home SMP Thu Feb 13 17:34:28 CET 2020 x86_64 x86_64 x86_64 GNU/Linux
    I tried to add the repo with this command but I got an error.
    HTML Code:
    # rpm -Uvh https://repo.zabbix.com/zabbix/6.0/rhel/8/x86_64/zabbix-agent-6.0.7-1.el8.x86_64.rpm
    Retrieving https://repo.zabbix.com/zabbix/6.0/rhel/8/x86_64/zabbix-agent-6.0.7-1.el8.x86_64.rpm
    warning: /var/tmp/rpm-tmp.ICI8Iv: Header V4 RSA/SHA512 Signature, key ID a14fe591: NOKEY
    error: Failed dependencies:
    libcrypto.so.1.1()(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    libcrypto.so.1.1(OPENSSL_1_1_0)(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    libpcre2-8.so.0()(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    libssl.so.1.1()(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    libssl.so.1.1(OPENSSL_1_1_0)(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    libssl.so.1.1(OPENSSL_1_1_1)(64bit) is needed by zabbix-agent-6.0.7-1.el8.x86_64
    then I tried to install the dependencies but I got an error again
    Example
    HTML Code:
    # yum install libcrypto.so.1.1 -y
    Failed to set locale, defaulting to C
    No package libcrypto.so.1.1 available.
    Error: Nothing to do
    any idea or help would be grateful
    Ostad
  • Answer selected by Ostad at 29-09-2022, 19:40.
    Ostad
    • Jul 2022
    • 10
    Solution:
    HTML Code:
    # rpm -Uvh https://repo.zabbix.com/zabbix/6.0/rhel/7/x86_64/zabbix-release-6.0-4.el7.noarch.rpm
    HTML Code:
    # yum clean all
    HTML Code:
    rpm -i http://mirror.centos.org/centos/7/os...el7.x86_64.rpm
    HTML Code:
    yum install zabbix-agent2
    • Ostad
      • Jul 2022
      • 10
      Solution:
      HTML Code:
      HTML Code:
      # yum clean all
      HTML Code:
      HTML Code:
      • Eric_B
        • Mar 2018
        • 75
        Originally posted by Ostad
        Solution:
        HTML Code:
        HTML Code:
        # yum clean all
        HTML Code:
        HTML Code:
        Hello, don't understant this line :
        HTML Code:
        • Ostad
          Ostad commented
          removed centos7 custom release repo from my machine and installed the right one.
      • MightyJainesh
        • Oct 2022
        HTML Code:
        What is the full URL?
        • ngarry1991
          • Jan 2023
          Did you ever get the full URL?
          Im getting the below error when trying to upgrade
          Error: Package: zabbix-agent-6.0.13-release1.el8.x86_64 (zabbix)
          Requires: libpcre2-8.so.0()(64bit)
          • ngarry1991
            • Jan 2023
            Just to add this was what I ran to get it working:
            rpm -Uvh http://mirror.centos.org/centos/7/os...el7.x86_64.rpm
            • chusmanali20
              • Aug 2023
              Solution For Zabbix Agent 6.0.21 for Alma-Linux 8.1,8.2 XCP-NG
              Download wget https://repo.almalinux.org/almalinux...8_6.x86_64.rpm
              yum localinstall pcre2-10.32-3.el8_6.x86_64.rpm
              systemctl enable zabbix-agent
              systemctl start zabbix-agent
              systemctl status zabbix-agent
              Thanks​
              • datacare
                • Dec 2021
                • 22
                Looking for a solution to install Zabbix 7.0 agent on XCP-NG 8.3 the code for above seems to be for older versions. Does anyone have a more up-to-date solution for the newer release?
                Thanks in advance!
                Rob
                • datacare
                  • Dec 2021
                  • 22
                  For anyone trying to get Zabbix Agent 7.0 installed on XCP-NG 8.3 These are the steps that finally worked for me. I ran these steps on several XCP-NG 8.3 hosts and it worked every time
                  Installing a Zabbix Agent on XCP-NG for Zabbix 7.0 involves the following steps:
                  1. yum update
                  2. yum install https://repo.zabbix.com/zabbix/7.0/r...el7.noarch.rpm
                  3. yum update && yum install -y pcre2 --enablerepo=epel,base,updates
                  4. yum install zabbix-agent
                  5. nano /etc/zabbix/zabbix_agentd.conf (edit the configuration file)
                  6. systemctl restart zabbix-agent
                  7. systemctl enable zabbix-agent
