I have 1 question about UDP port
  • Tam Dang
    • Aug 2022
    Hi guys!
    I am doing simple check with UDP port 123
    key as follows: net.udp.service[ntp,myIP,123]
    As result always return 0 (down)
    When I use the command: nc -zvu 172.16.60.68 123
    The result is as follows: Connection to 172.16.60.68 123 port [udp/ntp] succeeded!
    It means my port 123 has ntp protocol open
    But when monitoring on zabbix, it still returns 0.
    I'm a newbie, have searched for related questions but to no avail. Hope you guys can help me
    Thanks all!
  • Hamardaban
    • May 2019
    • 2714
    Zabbix is waiting for the correct response from the ntp server
    https://www.zabbix.com/documentation...et.udp.service
    Item net.udp.service parameters
    Sends an SNTP packet over UDP and validates the response according to RFC 4330, section 5. Default port 123 is used if not specified.
    You can use third-party utilities like nmap to detect open UDP ports and transfer data to zabbix.
    Due to the features of the UDP protocol, it is not easy to create a universal solution.
    • Tam Dang
      • Aug 2022
      Thank you so much,
      Is there any way I can monitor the udp port as is the case I am having? it's very important to me right now
      • Hamardaban
        • May 2019
        • 2714
        If a zabbix agent is installed on the host, then you can use agent checks net.udp.xxxx (not simple checks!) https://www.zabbix.com/documentation...s/zabbix_agent
        The problem is not new - read at least this https://support.zabbix.com/browse/ZBXNEXT-6501
        • Tam Dang
          • Aug 2022
          https://linuxhint.com/nmap_scan_udp_port/
          Thank you so much,
          I will do more research
