Multiple expression in a trigger
  • Xyue
    • Jan 2016
    • 93
    Hi guys,
    I am trying to monitor the power supply status of my switch. I have two power supply on my switches so I have created 2 Item which will monitor each of the power supply as it was using different OID.
    I tried to create a trigger with 2 expression but it was not allow as it shows me incorrect expression. Below is the expression i put in the trigger.
    Expression
    {1IDF-45-SW1:PowerSupply2.change()}<>0 OR {1IDF-45-SW1:PowerSupply1.change()}<>0
    Can anyone advise any problem on the expression or is it 1 trigger only can input 1 expression ?
    Thank you very much.
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Use lowercase "or". I'd suggest reading docs one more time.
    • Xyue
      • Jan 2016
      • 93
      Thanks. I missed out that part and though i should use capital letter.
      Thanks again for your help
