I have fresh installed zabbix 6.2 on ubuntu 22.02
need to change ip and domain for my zabbix, but getting erro 404.
need help thanks
more /etc/zabbix/nginx.conf
server {
listen 8123;
server_name _;
# server_name 10.20.0.11;
# server_name zabbix.xxxx.com;
root /usr/share/zabbix;
index index.php;
location = /favicon.ico {
log_not_found off;
location / {
try_files $uri $uri/ =404;
location /assets {
access_log off;
expires 10d;
location ~ /\.ht {
deny all;
location ~ /(api\/|conf[^\.]|include|locale) {
deny all;
return 404;
location /vendor {
deny all;
return 404;
location ~ [^/]\.php(/|$) {
fastcgi_pass unix:/var/run/php/zabbix.sock;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_index index.php;
fastcgi_param DOCUMENT_ROOT /usr/share/zabbix;
fastcgi_param SCRIPT_FILENAME /usr/share/zabbix$fastcgi_script_name;
fastcgi_param PATH_TRANSLATED /usr/share/zabbix$fastcgi_script_name;
include fastcgi_params;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_intercept_errors on;
fastcgi_ignore_client_abort off;
fastcgi_connect_timeout 60;
fastcgi_send_timeout 180;
fastcgi_read_timeout 180;
fastcgi_buffer_size 128k;
fastcgi_buffers 4 256k;
fastcgi_busy_buffers_size 256k;
fastcgi_temp_file_write_size 256k;
need help thanks
server {
listen 8123;
server_name _;
index index.php;
log_not_found off;
location / {
location /assets {
access_log off;
expires 10d;
location ~ /\.ht {
deny all;
deny all;
return 404;
location /vendor {
deny all;
return 404;
