Status of Discovery Screen Errors
  • adfrost
    • May 2022
    I'd like to check on the discovery status, but I have two issues (probably related to each other).
    1. When loading the screen, it initally displays, but there are a ton of errors/warnings at the top.
Name:	2022-08-16 15_56_07-Status of discovery.png
    2. It never completes loading and eventually just displays an Out of Memory error. It seems like the main issue is that it's trying to display all discovery data at once and never finishes loading it. I'd like to filter it, but it won't even allow me to select the Discovery Rule field and enter anything.
    I've also tried altering the "Rows per page" setting to a very small number, but it does not seem to impact that particular screen.
    Lastly, tried entering the search terms directly into the URL, but because I don't know the name of the Discovery Rule field, I'm just guessing at what it might be. (zabbix.php?action=discovery.view&filter_rule=chs.str.3011.kiosk.action&filter_status=-1&filter_set=1)
    If anyone knows what that would be called, I'd love to give it a try.
