log file monitor basic
  • Lake
    • Feb 2016
    Hi again.
    Big thanks for this forum getting know better of Zabbix.
    So I try to start monitor log files.
    I have try to search forums old tips, but not find right one.
    My goal is monitor log file and grep error (non key sense) words from there.
    so I have made Item and key of that is like
    log[/tmp/log.log,error]
    now I should do trigger, right?
    // Lake
  • Lake
    • Feb 2016
    I found one way to do this.
    Also I can create graphs from log file.
    Items:
    Name: Test Log Monitoring
    Type: Zabbix agent(active)
    Key: log[/tmp/log.log,(error|OK)]
    Name: Test Log error count
    Type: Calculated
    Key: Test.log.error.count
    Formula: count("log[/tmp/log.log,(error|OK)]", 60,"error","like")
    Name: Test Log OK count
    Type: Calculated
    Key: Test.log.OK.count
    Formula: count("log[/tmp/log.log,(error|OK)]", 60,"OK","like")
    Trigger:
    Name: Test Log Error Trigger
    Expression: {server:Test.log.error.count.last(0)}>0
    //Lake
    • Firm
      • Dec 2009
      • 342
      You send log file entries matched you filter to Zabbix with help of log[]. You create trigger using string or regexp matching to data you received.
