Zabbix server: Utilization of poller data collector processes in 100%
  • Mursel.BAKAY
    • Jun 2022
    • 12
    Hi all,
    I have a problem about zabbix server: "Zabbix server: Utilization of poller processes over 75%." I checked it and this value is 100% for me.
    I increased StartPollers value at my zabbix_server.conf file. I set this value like 5, 10, 50, and I restart zabbix-server.service. But it doesn't work for me, my poller processes is always 100%.
    How can I do? Can you help me, please?
    Thanks.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Maybe you have too many and too frequent checks? What is the value of NVPS in System Information dashboard widget?
    • Mursel.BAKAY
      Mursel.BAKAY commented
      The value of NVPS is 67.12. Is this value normal or not?
      Thanks.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Yes, it is fine. Does the problem go away if you set StartPollers to 100?
    • Mursel.BAKAY
      Hi dimir,
      Thanks for your help. I set StartPoolers to 100 and my issue is solved now. But this problem comes up again and again. Sometimes it fixes itself. But there is no problem now.
      Best regards, thanks again.
  • jtalbot-mag
    • Sep 2021
    Is there a way to modify the StartPollers from the UI or must this be done in the zabbix_server.conf​ file?
      • 4970
      it is in config file...
      • lptarik
        • Oct 2021
        • 33
        Is this process related to unreachable data collector ? They both in 100%
        • adrian_c
          adrian_c commented
          If your unreachable pollers is 100%, then you must have some hosts that aren't available, try increasing "StartPollersUnreachable" in your server config file, default value is 1.
