Macro containing LLD object name
  • mbrackeva
    • Feb 2016
    • 27
    I'm setting up an integration between Zabbix and our central monitoring console. This works fine using actions with remote commands. I can call a binary with the necessary arguments for sending the alert to the console.
    There is one argumenjt however I can't seem to find. It concerns LLD triggers.
    For example, if a file system's space usage is over threshold I want to include the name of the file system as an argument to the action's remote command. I tried a lot of possibilities, but I can't seem to find it. Any ideas?
